Twin Intake pump guys check in
Old Jul 9, 2006 | 01:19 PM
02SSLE's Avatar
Default Twin Intake pump guys check in
Like the title says I have a drop in fuel preasure under boost. I have a GMR fuel system the system has 2 340 gph Walbro pumps in take. No hot wire kit. Under boost the fuel presure drops to 50 amd stays there. Should I be concearnd? I wouldn't think I should have any fuel presure drop with the amount of pump I have.
Old Jul 9, 2006 | 01:27 PM
Got Me SOM's Avatar
do you have a regulator?
is your fuel economy any worse with twin pumps now? I may be switching to that in the future.
Old Jul 9, 2006 | 02:15 PM
RDTA's Avatar
hey man, Im a buddy of shanes, but anyway he is running a aeromotive reg. with a boost referance. I really dont think he lost any milage. He said he got like 20 plus mpg coming hime from GMR. brian
Old Jul 9, 2006 | 02:38 PM
Got Me SOM's Avatar
tha's cool.. i'm lucky if i get 18.. I know my tune is off though on part throttle.
Old Jul 9, 2006 | 02:57 PM
02SSLE's Avatar
yeah I raced all night last night and still have over 200 miles on the tank. Thinking about putting electric cutout on this week and redynoing it next weekend I think my power is up because we had exhaust leaks we didn't know about at the time of tune. after I had them fixed the boost comes on faster and have more psi.Been having to turn fuel preasure up to get the spark plug the way it needs too look so it is holding 18 psi now.
Old Jul 9, 2006 | 04:40 PM
qqwqeqwrqwqtq's Avatar
It should not drop, you have more than enough pump. FP should rise with manifold pressure.
Old Jul 9, 2006 | 04:49 PM
02SSLE's Avatar
what do you think the problem is?
Old Jul 9, 2006 | 04:53 PM
MECHAM's Avatar
https://ls1tech.com/forums/showthrea...ghlight=mecham
Old Jul 9, 2006 | 07:59 PM
Not sure, but we've ran dual walbros to nearly 1000rwhp through a T400 and stock feed line/filter with no issues at all. (also at 850+rwhp with 60lb injectors with 70psi base pressure).
Old Jul 9, 2006 | 08:26 PM
02SSLE's Avatar
I cranked the base preasure too 72 and the plugs show it's fine threw the run. Just dips to 50 on the big end.
KAOS's Avatar
intmd8 you just run stock feed line and two pumps? nothing else..sorry for highjacking
Old Jul 11, 2006 | 06:11 AM
02SSLE's Avatar
any other ideas?
Old Jul 11, 2006 | 08:38 AM
MECHAM's Avatar
did u try lowering the base FP to 43.5psi?
Old Jul 11, 2006 | 09:35 PM
KAOS's Avatar
intmd8???
Old Jul 11, 2006 | 09:50 PM
Stock feed line and fuel filter, new rails, regulator up front and dual walbros on many 850+rwhp customer cars.
I use dual walbros on my own car but no stock lines due to dual fuel systems.
Old Jul 17, 2006 | 10:06 PM
TURBO383WS6's Avatar
i'm running into this same problem now. what boost referenced FPR does every1 recommend and what rails should i use on an LT1 car w/ 72# injectors? should my stock lines really do the job or should they be replaced?
