L36/LS1 fuel pump question
Old Jul 13, 2006 | 09:00 PM
super_kev's Avatar
Default L36/LS1 fuel pump question
I have a '02 V6 fuel pump assembly, and it looks identical to my '02 LS1 fuel pump unit. Are they the same, or are the pumps the only difference? Reason is because I don't need it and want to sell it, but I'm not sure if there's a difference (i.e., in the ad: "works with LS1" or "works with V6 only").
Thanks.
Old Jul 18, 2006 | 01:26 PM
super_kev's Avatar
So I take it that they are the same?
Old Jul 18, 2006 | 03:03 PM
connexion2005's Avatar
Im not 100 percent on this answer but I've been told that the answer is no. They may look the same but the ls1 pump produces a higher flow rate and more psi. If it fits the v6 i dont see a problem with a more powerful pump. Basically Ls1 pumps are probably ok for v6's but v6 pumps arent ok for Ls1's...Josh.
