Extra Pickup on Pump/Bucket?
Old Jul 16, 2006 | 04:46 PM
OldSchoolFormula's Avatar
Default Extra Pickup on Pump/Bucket?
Can anyone explain to me what the purpose of the small skinny line is that runs from the top fof the pump down to the external sock on the bucket? What does it do? Also, how do I disconnect the plastic lines from the pump itself? They are on there pretty good...
Thanks
Old Jul 16, 2006 | 06:56 PM
oange ss's Avatar
it's a venturi feed system that bleeds off pump pressure to create a vacuum over the bucket inlet to keep fuel in the bucket especially under low fuel conditons.....cut them off
Old Jul 16, 2006 | 07:07 PM
JDubs's Avatar
I wish I would have read this a couple hours ago. I went through a lot of trouble to put that little line on my new pump!
Old Jul 16, 2006 | 07:09 PM
oange ss's Avatar
if the pump is equiped, then it's a good idea to use it
Old Jul 16, 2006 | 07:36 PM
JDubs's Avatar
The new pump had a place for it but no fitting. It was a pain getting the old fitting from the old to the new. And then it was spaced really close to the main output line and the hoses didn't fit well. Well, its done now and she runs!
Old Jul 16, 2006 | 10:15 PM
Shoot, I thought the one way valve in the bottom of the bucket and the return line was all thats needed to keep the bucket full. Guess not. But how does it make a vaccum in the bucket? The buckets not sealed...
Old Jul 17, 2006 | 03:24 AM
Duh...now I get it. Found this on Racetronix site, so here it is for future reference for anyone else. http://www.racetronix.com/RX-F99-FPKG-2.html
"The 1999 & up LS1 F-body cars have a pump that is inside a plastic fill-bucket. The fill-bucket is equipped with two inlets on the bottom. The equalization checkvalve is used to fill the bucket when the level of fuel in the tank is greater than in the bucket. The equalization checkvalve does not allow fuel to exit the bucket. The venturi system's inlet is a combination checkvalve and powered suction system. The factory pump supplies pressurized fuel via a small tube which feeds a calibrated jet inside the venturi system. This jet of fuel shoots across the base of the checkvalve inlet thereby creating a suction effect which draws more fuel from the bottom of the tank through the filter sock. This venturi system keeps the bucket full all the time even when the fuel tank is almost empty. A full bucket keeps the pump immersed in fuel regardless of the tank level so that when the tank is low on gas and you are doing some hard cornering or acceleration the pump does not run dry and start aerating (air bubbles) the fuel. This happens as the fuel sloshes from side to side in the tank leaving the center low on fuel. This can cause detonation and possible engine damage. The 99+ F-LS1 cars with plastic tanks have no baffling in them so the bucket is very important. The bucket also allows the car to operate with lower fuel levels in the tank due to its scavenging effect. The fill-bucket improves motor crank-to-run time as the priming time is reduced under most conditions. The return line feeds the pressure regulator on the fuel module which diverts fuel back into the bucket so that the unused fuel also helps keep it full at all times. Keeping the pump constantly immersed in gas within the bucket can extend the pump's life by not allowing it to be exposed to open air. Open air within the tank contains moisture and in time will cause the pump to rust / seize up especially if left to sit for long periods of time without the tank topped-up (i.e. winter storage)."
