MAF air leak causing "too lean code"?
Old Jul 17, 2006 | 02:07 PM
robertbartsch's Avatar
Default MAF air leak causing "too lean code"?
Any thoughts? This is one possible solution listed to cure a PO171 code - too lean Bank 1.
Old Jul 19, 2006 | 12:09 AM
Jpr5690's Avatar
Dont Sound Right.... But Its Easy Enough To Check For
Old Jul 19, 2006 | 07:17 AM
slowpoke96z28's Avatar
any unaccounted air that gets in the intake can cause this code. use a can of brake clean to try and find the vacuum leak
Old Jul 19, 2006 | 09:14 AM
...it was not a vacume leak - the aftermarket MAF was toast. I replacecd it with the factory MAF and BING - the car runs great.
Thanks...
