fuel system diagram
Old Jul 26, 2006 | 11:31 AM
str8-6's Avatar
Default fuel system diagram
i just replaced the 3 fuel lines on my 94 camaro. (the ones in the middle of the car around the fuel filter) now i guess when i was disconnecting the old ones i accidently pulled a line off somewhere else. i found the line its the one coming from the canister/overflow thing near the filler cap, ( if you remove the plastic around the filler cap its on the rear side) its the middle line of the 3. what im trying to do is figure out where exactly its plugs into without dropping the fuel tank( exhaust welded on). if anyone can tell me which line this runs into or give me a diagram. thanks
