need help with seleting fuel line and pump
stock bottom end
gtp stage 2 ported heads
fm7 blower cam
ls6 intake
ported throttle body
vortech v9 i think its a g trim ( planned on 7 to 8 psi)
plan to run meth
42 lb injectors
areomotive fpr
intank walbro 255
now is the stock fuel lines and pump going to handle that
also i mite getting a set of low compression pistons and turn up the boost from anywhere around 10 to 15psi
I have an a1000 and some 6an line i was thinking about running but what size would i need for the return line and is it worth doing or overkill
at sametime would the set up i have with the 255 be not enough or be working at its max Yhis a full street car and will be raking up the miles
but now i dont know if the g trim will supply enough but i am going to be shifting from 6000 to about 6500 rpm
i need some guidance
Please
