new fuel pump, noticing some problems
Old Aug 10, 2006 | 11:10 PM
chrisryn64's Avatar
Default new fuel pump, noticing some problems
I had a new stock fuel pump put into my 98 ls1
Afterwards I can't seem to fill my tank all the way up. Every pump I've tried will click off before letting me fill it to the max.
I also seem to be getting much worse gas mileage
What are some possible things causing this?
Old Aug 11, 2006 | 08:49 PM
chrisryn64's Avatar
...bump....
Old Aug 14, 2006 | 09:42 AM
chrisryn64's Avatar
no one?
Old Aug 14, 2006 | 07:51 PM
Bad N Black's Avatar
The 15" fill tube is kinked. It is inside the drivers rear wheel well. There is a plastic piece you can take out & get right to the fill tube. You might need to slide it on more. It is much like a radiator hose.
Hope this helps
