Whats your mpg?
about 75/25 does anyone know what might be wrong please help me out shoot me a pm its a 95 trans am
- just bugginghave you had recent tune up? injectors purged?
when my engines got slap they lost alot of millage.
Keep in mind that EPA estimates are based on vehicles driven/tested on a 'closed course' and they are not generally accurate for most drivers.
Wish I could drive as easy as you can friend.
I would think that 24mpg is normal for your miles and your car.
When I did my homework prior to purchasing the car this past April, based on EPA mileage estimates and polling some LS1 owners at work, I projected 15 or 16 in town, which is what I would find satisfactory.
I find the 13 very disappointing and really the ONLY negative about an otherwise outstanding car. Any suggestions on what might be wrong? The car is stock from a performace standpoint, with the only mods being window tint, skip-shift and B&M shifter.
I'd appreciate any help.
Best regards,
Jeff T.
Well... I'll list the most simple things you can do.
1: Check Tire pressure- It is true if your tires are off a few PSI it will affect your fuel economy alot.
2: Clean you air filter/ replace it with a new one
3: Try to shift earlier if you are babying it
4: Run some fuel injector cleaner through it. ( A product called seafoam works great ,just dump the can in a full tank and it will work its magic)
If it comes down to it, usually an aftermarket intake/exhaust will help fuel economy but will come at a cost.
Good Luck
After mods not done a full tank average, about 16mpg around town, 24mpg on the highway. During heavy acceleration 1.05mpg in first gear and 2.2mpg in 2nd gear.
Good Luck
I get about 16 mpg on avg with all city driving.
but its good for mpg when the wind is behind you.
