Noob fuel cell and pump question
My current plan is a fuel cell in the trunk. I do not want to cut my trunk up.
Do fuel cells need to supply out the bottom? (cutting trunk)? or are there top feed ones?
I have an A1000 external pump already, can it pull from a top feed if there is such a thing or does it have to be pulling from a botton feed?
I will be setting up from scratch as the only part I have is the A1000 pump which I would get rid of if it won't do what I need.
Also do fuel cells have intank pumps?
Any suggestions or help will be greatly appreaciated. HP at crank might be from 500-600 N/A and I will next year be spraying 150-200 on it wet probaly.
What would you setup if you were me?
Nate
Nate
I was looking over the car tonight and I really wish I didn't have to use a cell. The stock fuel take would be so easy to use but looking at the size of the feed line that was going to a Holley blue pump in the truck, I don't think it is larger enough. What is the minimum for the feed for an A1000 external pump? Maybe I should pull the tank and weld in one of those bottom tank sump things. Hmmm..
