throttle body
Old Sep 1, 2006 | 06:57 AM
berty's Avatar
Default throttle body
hi guys need a bit of input here,is any one on here using a 1000 cfm trottle body for a turbo set up,iam in two mind weather to go this route and make a hat for the top and just blow through or my next oppitions is to go for one of these 90degree foward facing elbows and use a 90 mm accufab throttle body but will i be able to used this with an ( AIC ) AIR IDLE CONTROL VALVE does any one knows the overal hight of these elbows from the base where it bolts to the manifold to where it bend through the 90 dregee tt 383 escort on the way
