Fuel rail cap
Old Sep 1, 2006 | 11:07 AM
Ricky_GD's Avatar
Default Fuel rail cap
How important is the fuel rail bleed valve cap? iv managed to loose mine
also will this valve leak at anypoint ( if the pressure is too low/high?) im using an adjustable regulater and havent checked the pressure yet but the valve is opening as the pump builds up the pressure then closes. opens again when the pressure drops a little ( on start up)
anyideas??
regards
Old Sep 1, 2006 | 11:11 AM
Nasty N8's Avatar
Its not supose to it is like a tire valve until you depress it it should not leak. The cap is a just in case and to keep dirt out.
Nate
Old Sep 1, 2006 | 11:15 AM
Ricky_GD's Avatar
Right thought as much will have another look tommorow. maybe some dirt has got in there.
