fuel filter question CARB or Fuel Injection
sumped 98 tank
im running twin exturnal pumps....
and i would like to place a fliter before each pump...now the fuel will be coming out of my tabk into the filter and then into the pumps....
can i use the summit filters set up for carb cars cause the pressure wont be as high since its before the pumps...
just asking cause its a differnce of like 40 bucks
below is a visual of what exactly i am trying to achieve..
anyone know waht filters these are???
2 anyone know what the part number is for these an fittings they are
10mm to -8
10micron.
The prefilter micron rating should be NO less than 40.. Some pump mfgrs look at 70 to 100 as being OK.
The after pump filter[s] should be 10 micron, w/ enough flow capacity to handle the volume.
I use the Aeromotive, stainless cartridge filters as a pre-filter, and the paper elements after the pump.
The restriction that the carb filters cause, can/will create cavitation in the inlet of the pump.. That will do 2 things:
1.Destroy the pump.
2. Create enough vacuum to cause the fuel to boil.
