How To Install A Fuel Pump
Old Sep 4, 2006 | 01:16 PM
fstls1camaro's Avatar
Default How To Install A Fuel Pump
I am about to get a fuel pump and i want to know if it is hard or easy to install. if you have instructions on how to do it i would appreciate it.it is a 2000 camaro ls1.
Old Sep 4, 2006 | 03:15 PM
connexion2005's Avatar
search for the trap door method of installation...f body's can be a pita if you do it by the books...i used the trap door method and not only was it not that bad, i know have a cool little access door if i ever need to get back in there...j.g.
Old Sep 4, 2006 | 07:11 PM
obrien24's Avatar
Its not hard to do at all. Since I have true duals, and didn't want to cut up my car, I dropped the tank. You only have to remove the panhard bar, and the support bar above it for the tank to clear the rear end. If your exhaust is going to be an issue, then you may want to consider the trap door method.
Old Sep 8, 2006 | 05:13 AM
JL ws-6's Avatar
Race your car!
I did mine on a saturday, racetronix kit with the hotwire setup, I dropped teh tanka dn removed the catback, really wasn't that bad. Just have the tank empty, because it will be too heavy if it's not. It's a 2 person job too, no way you can put the tank back in alone, trust me on that.
Old Sep 9, 2006 | 10:26 PM
obrien24's Avatar
sure you can, you just need a floor jack to help get it up in the air. I just used the floor jack and a piece of wood until I could get underneath it, and then I put the straps in place.
Old Sep 10, 2006 | 10:01 AM
HavATampa's Avatar
I dropped my tank and re-installed it by myself when upgrading the fuel pump. It would be easier with 2 people, but it's not impossible. A lot of people cut an opening to access the pump instead of dropping the tank. Here's a link to cutting the hatch on an LT1. http://www.geocities.com/formulapower2/fuelpump.html
Search this forum for dropping tank and you'll find a lot of info. Racetronix recommends dropping the tank so you can flush it while you have it out.
Old Sep 11, 2006 | 01:01 PM
Thanks for your input it helped alot.
