More fuel problems
Pressure is droping 10psi at WOT above 5000 rpm. It is set at 70, goes up to 80, and comes back down above 5000 rpm. I know 70 is high. But it isn't my doing. The tuner set it up like that. The reg. is boost senstive. I guess one of 2 things could be going on. Losing boost, and it is letting it out like that, OR voltage is droping, and it is effecting the pump? It still pulls hard with part throttle, so I don't think it is boost problem, but I will double check.
Fuel system is nasty performance rails, reg, line, and 340 intank pump with 60lb. injectors.
Any thought why we are losing that much pressure? It seems like a lot of people are running a boost a pump with upgraded systems. Doesn't this defeat the purpose of having a larger intank pump?
Need help.........
