Stock Fuel Rail Question.
Old Sep 8, 2006 | 12:45 AM
Revson's Avatar
Default Stock Fuel Rail Question.
I am doing a ls1 into 59 Corvette conversion. I am going to run a stock short block (for now) with AFR 205 heads (milled to 60CC), MS3 cam (or close), and a LS6 intake w ported throttle body. I know I have to build a return type fuel system, but my question is will stock fuel rails modded into a return type flow enough fuel for this setup. So far I have a Walboro 255 pump, aeromotive regulator and filter, and will probaly get around 38lb injectors. Any advice you could give me would be greatly appreciated.
Old Sep 8, 2006 | 01:01 AM
Wnts2Go10O's Avatar
return style reg and youre fine
By Brett Foote | 2026-06-04 05:00:17
