fuel pressure regulator going??
is there anyway to change the stock one without a whole new rail?
Usually running the rails at 57PSI, has dropped to 40PSI, so thought it was the pump, then have seen 65PSI which points to regualtor.
If they go, whats a good aftermarket replacement, its it a straight swap for the stock one?
I think the item between the two fuel rails is to balance the pressure between the two rails?. I removed that and still have fuel rail reguation (most of the time)
