Fuel heat
Old Sep 19, 2006 | 11:41 PM
Ari G's Avatar
Default Fuel heat
Is anyone runnig a fuel cooler or has anyone measured there fuel temps?
Old Sep 26, 2006 | 10:32 AM
1999 SS's Avatar
i didnt know there was such a thing. i would like to hear more about it.
Old Sep 26, 2006 | 11:58 AM
V6 Bird's Avatar
Are you experiencing any problems with a particular setup that raises this question?
Old Oct 1, 2006 | 02:31 AM
RedHardSupra's Avatar
i wanna hear more on this as well, i'd like to improve stability of fuel temperature to make tuning more consistant. i noticed that if you fill up your tank of gas with fresh gas, your fuel trims go completely crazy and after few mins they fall back inline--i'm guessing it's temperature. i've considered a cooling can, but i dont want the atomization of fuel get worse due to temperature drop, so for now i just wanna monitor it. any particular parts/setups i should look into?
Old Oct 1, 2006 | 02:45 AM
alky's Avatar
If you run a true return style fuel system (pump to rails to adj fp reg back to tank) the fuel in the tank heats up substantially.
Flex-a-lite sells a fuel cooler with 6an fittings. Part # flx-4136 for $39.95 @ summit. It looks like a small oil cooler.
I have not tried this yet but I have been looking into it. I would instal at the rear of the car befor returning to tank.
Old Oct 1, 2006 | 11:35 AM
curtisad's Avatar
Diesels have a fuel cooler mounted in front of the gas tank. I don't know if it would help any put it couldn't hurt.
Old Oct 1, 2006 | 11:39 AM
Ari G's Avatar
No,but i haven´t seen anyone cooling there fuel to push the boost up
If anyone knows the perfect fuel temp or any info i would like to know,i´m building a TT engine so detonation is a concern on fuel pump
