could this be a bad fuel pump please help
Old Sep 20, 2006 | 05:40 AM
02blkws6vert's Avatar
Default could this be a bad fuel pump please help
when you turn the key on you should hear the fuel pump correct? ok my car is at the garage getting a new slave cylinder installed and now it wont start and the guy hasnt even started working on it, so i went there and added fuel and it turns over but wont start, i cant hear the fuel pump come on so could that be the problem? thanks for any help
Old Sep 20, 2006 | 06:37 AM
RedWS6 00's Avatar
I guess the fuel pump has a fuse, check that, either in the end of the dash or under the hood.
Had the guy started any work at all? could he have knocked something?
What about an aftermarket immobiliser? perhaps it some how got enabled?
Havn't known pumps to just go like that.
Old Sep 20, 2006 | 01:22 PM
connexion2005's Avatar
Check your fuse, if still nothing then yes it is most likely the pump. If you decide to swap the pump when you get to, use a volt meter on the positive and negative and turn the key forward to make sure absolutley its the pump and not cold wiring.
Old Sep 24, 2006 | 01:58 AM
which fuse is it where is it at? thanks
Old Sep 24, 2006 | 10:32 AM
SS30ANV's Avatar
Check fuses in engine bay and inside car....but more importantly if fuses are ok....check fuel pump relay under driver's side kick panel....at least that's where it is in my 97' SS.
Thought my pump went out but was the relay instead....new relay about $35.
Here's a link showing relay location on a 95'Z28....not sure if your 2002 is the same, but worth the try.
http://shbox.com/1/fuel_pump_relay.jpg
Old Sep 24, 2006 | 10:34 AM
SS30ANV's Avatar
Oh, and you may as well change your fuel filter just to be sure it's not plugged.
