boost a pump?
Old Oct 29, 2006 | 07:13 PM
Tirefire's Avatar
So how would someone know if a boost a pump does'nt work?? I here people on this thread say that a BAP helps maintain fuel pressure, but mine does not seem to maintain even after a new fuel pump..
Old Oct 29, 2006 | 08:01 PM
Jake@EPP's Avatar
The BAP boosts the fuel pressure up. When set to full , it will send around 17v to the pump. Best way to make sure is to trigger it while using a multi-meter.
Whats going on with yours Ande?
Old Oct 29, 2006 | 10:55 PM
Tirefire's Avatar
Well I finally replaced the pump which gave out on me last week on the highway. I drove the car yesterday and it felt a lot better, but I still noticed that the fuel pressure was dipping into the 52 psi area. So I don't know what could be causing my fuel pressure to drop that low. The old pump was part of the problem I believe because at idle I was only seeing about 52-54 psi. I changed the filter and I also checked the pressure at the rail and it showed 60 psi like my autometer gauge showed. How would you set the BAP to full?
