Fuel Pump
Old Oct 15, 2006 | 08:04 PM
qualls86ta's Avatar
Default Fuel Pump
Im doing an ls1 3rd gen swap and i am going to run an inline fuel pump, however i don't know what size i need, so if you could let me know what size i need or even what pump to run
Old Oct 15, 2006 | 08:35 PM
STALL UP's Avatar
255lph inline walbro
Old Oct 15, 2006 | 09:33 PM
qualls86ta's Avatar
Where is the best place to get one at?
Old Oct 15, 2006 | 09:43 PM
qualls86ta's Avatar
Plus it is a heads/cam motor that has about 550 hp
Old Oct 15, 2006 | 10:36 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If you are keeping your 3rd gen tank please consider this system which has provision for a pump booster or optional in-line pump.
http://www.racetronix.com/product/RX..._Pump_Kit.html
Depending on your motor's BSFC, max. fuel pressure and desired A/F this system may be enough as it supports 500-600RHWP.
Thunder Racing stocks these kits as well.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Oct 19, 2006 | 10:43 AM
ALL UC2's Avatar
jsut run a 4th gen tank and a intank. they will bolt right in.
Old Oct 19, 2006 | 11:31 AM
Nasty N8's Avatar
We have 255 inlines in stock or can set you up with anything in-between. You have many options.
Nate
