tank question
Old Oct 17, 2006 | 09:25 PM
daniel6718's Avatar
Default tank question
i want to put a platic tank in my lt1 car..which if any ls1 plastic tank car(99-02) have a return style system...to the tank...lt1 have a pressure line return line and an evap line i think is what its called for ventillation (which i have removed so its not necessary)
ive heard of others doing the swap so im pretty sure its possible, just need to know how
thanks
Old Oct 19, 2006 | 11:47 AM
Nasty N8's Avatar
All the 99-02 tanks are the same but they do have a feed, return and a vent on the sender. Why put a plastic tank in your car? The steel tank is much easier to work with when installing pumps.
Nate
Old Oct 19, 2006 | 03:22 PM
daniel6718's Avatar
weight...hear they are about 20 pounds less...
Old Oct 19, 2006 | 06:20 PM
1redta's Avatar
Default re
because you can put an adapter to run a bigger pump by drilling a hole in the bottom of the plastic tank? you have to sump metal tanks
