fuel system setup to support 550rwhp
Old Oct 21, 2006 | 09:51 PM
96ta's Avatar
Default fuel system setup to support 550rwhp
i was considering buying the aeromotive fuel system setup that can support 1000hp but i dont want to spend 1400 if i can get something to work as good for cheaper......the setup is for a heads/cam car only
Old Oct 21, 2006 | 09:57 PM
onfire's Avatar
Coal Mining Director
Racetronix will easily support 550rwhp for ~ $250. Harris Speed Works, Thunder Racing, etc will hook you up.>>>>>>>
Old Oct 22, 2006 | 04:21 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
For heads/cam only, the stock pump will hold (close to?) 550rwhp if you run 60# injectors. The oversize on the injectors helps band aid the fuel pressure drop. This has worked for me to about 510rwhp turboed. Then again, too much is never enough, so just do a full aftermarket return system.
Old Oct 22, 2006 | 08:26 AM
The Red WS.6's Avatar
I've got the vortec inline-booster pump and worked like a charm at that power level, with 42lbr's.
Gametech has a great point. 42lbr's can support (not certain what you are planing to run, obviously) what you want, however, if you ever wanted to go with some sort of boost, juice, etc... the 42's Will choke the system. Get the bigger injector if this is in your not so distant future!
Old Oct 22, 2006 | 04:11 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
This is all I run at the 550sh rwhp level: 255 in tank pump, 60 lbs injectors, and the BAP. Everything else is stock (lines/rails/etc).
Old Oct 22, 2006 | 04:58 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
walbro 255 in tank does a fine job, i am over 500 on motor.
