Cut for fuel pump location
Old Oct 28, 2006 | 06:26 PM
03 BUSA's Avatar
Default Cut for fuel pump location
Can anyone direct me to the right spot on locating where to cut a hole in the trunk area to replace the fuel pump? I am going to make up a nice sheet metal cover once I am finished, but need to know where to cut. I know this has been talked about before but a search did not help. Thanks guys.
Old Oct 28, 2006 | 06:48 PM
YoMommasTA's Avatar
http://jobberonline.biz/Repairkitinstructions.html
Old Oct 28, 2006 | 07:42 PM
03 BUSA's Avatar
Originally Posted by YoMommasTA
Thanks but I am looking for the measurements for cutting the access hole to get to the fuel pump.
Old Oct 28, 2006 | 07:58 PM
YoMommasTA's Avatar
https://ls1tech.com/forums/showthrea...ight=trap+door go to this thread,there is lots of info there......also be sure you read carefully because 98 is a oddball year.Yours gets cut like the Lt1 cars.Cut a small hole and be carefull not too deep with the tools.93-98 gets cut diff than 99 up
Old Oct 29, 2006 | 10:16 AM
03 BUSA's Avatar
Thank you, that is what I needed.
Old Oct 29, 2006 | 10:17 AM
YoMommasTA's Avatar
you're welcome
