fuel rail fitting hitting firewall
I do not know how the responce was posted before the question
Keith
Do they have an "outer" side, such as with lettering, etc?
Are the inj holes drilled the same distance from the ends, on the 4 corners?
Are the threads set up for AN fittings, and o'rings, or pipe threads?
[I've not installed this system, so that's the reason behind the ??'s.]
If they are not drilled the same distance, can they be swapped side to side, to put the "short" side at the firewall?
If they have pipe threads, can the rail be cut off, and the threads extended further into the rail?
[AN threads could have the same mod, only the o'ring recess would have to be recut.]
