Fule pumps
Old Nov 5, 2006 | 09:01 PM
Justa Z's Avatar
Default Fule pumps
Im going with a carbed ls1 in my lt1 car, can i use the stock fule pump and the 255 walbro with this setup, i was told all i need is a regulator to turn the pressure down. Any help would be good. Thanks
Old Nov 6, 2006 | 07:50 AM
Old Geezer's Avatar
Exclamation Maybe, but..
Some carb system regulators do not have a range wide enough to accurately control pressure at the 6-8psi level, when hit w/ 40-60 psi.
Be sure to verify that capability, before you spend the cashola, and find you are skrewed..
