injector Question?
Old Nov 6, 2006 | 05:26 PM
STKN1STGEAR's Avatar
Default injector Question?
Hi All,
I am building an LS2 with LS1 ported heads with 2.02 /1.57 valves.
It will have a Vortec supercharger on it running approx 12 PSI.
It is going in a 99 SS Camaro.
My question is do I need more than 35# injectors or is that enough?
Thanks In advance
Al
Old Nov 6, 2006 | 05:39 PM
I found this on one of the other post
http://www.rceng.com/technical.htm
Thanks
Al
Old Nov 6, 2006 | 08:22 PM
Black Plague's Avatar
Go with 50's or 60's what ever you can get cheaper!
Old Nov 7, 2006 | 12:44 PM
Is it posible to have to much injector?
If I have to much injector and not enough pressure or flow to run them, isn't that worse then running 35# injectors at 60 -80% duty cycles?
Al
Old Nov 7, 2006 | 08:06 PM
Not really with the good injectors like MSD,Motoron. They can flow verry verry well at low duty cycle to and your tuner can tune for them that is the easy part! With your forced induction at that boost level I would buy injectors big and once! I am using MSD 50 pounders with my setup just fine. Afuel pump upgrade like the Racetronix PNP would be wise if you dont have one already.
Old Nov 7, 2006 | 11:58 PM
Thanks for the advice.
I'll consider it.
Al
