Fast Fuel Rail Kit
Old Nov 16, 2006 | 01:49 AM
TWINK's Avatar
Default Fast Fuel Rail Kit
I ordered this kit today from ws6store.com i just want to make shure that i will have everything to install it on my car with the new 90/90 set up.
here is the part number etc
98-02 LS1 FAST LSX Fuel Rail Kit (w/Fittings) (54023)
If you have any install tip's please post up...
Thank's
Old Nov 18, 2006 | 10:32 PM
N4cer's Avatar
Order a transmission.
Old Nov 19, 2006 | 02:58 PM
davered00ss's Avatar
Moderator
You need the fitting kit to attatch it to the stock fuel lines.
you need this.
you ordered this.
Old Nov 20, 2006 | 11:13 AM
Nasty N8's Avatar
Yes you will also need our install kit the FAST rails only come with a couple fittings I have made a complete kit with quick disconnect fitting.
Nate
Old Nov 20, 2006 | 01:53 PM
TWINK's Avatar
TH350
TWINK's Avatar
Is that the kit from fast ? how much $$$ was all that ?
[QUOTE=davered00ss]You need the fitting kit to attatch it to the stock fuel lines.
you need this.
Old Nov 20, 2006 | 01:55 PM
TWINK's Avatar
Nate
NastyPerformance fitting kit to connect F.A.S.T. fuel rails to the factory feed line. Includes stock style quick connect fitting. $139.99
Old Nov 20, 2006 | 02:04 PM
TWINK's Avatar
also what would be a good Fuel Pressure Regulator ?....
Old Nov 20, 2006 | 03:42 PM
Nasty N8's Avatar
We use either a Fuelabs or MagnaFuel. You are looking at alot more then an install kit to add a fuel regulator up front. What are you lookiing to do I can setup a kit for you.
Nate
Old Nov 20, 2006 | 05:06 PM
Moderator
That kit was from Nasty. $135 I think.
