stock fuel
Old Nov 27, 2006 | 04:10 PM
aaronbetzner's Avatar
Default stock fuel
I have a 231 237 cam and boltons on a 98 ss when will I need injectors and pump and which first?
Old Nov 27, 2006 | 06:51 PM
Nasty N8's Avatar
You will prob run out of pump about 430rwhp and injectors slightly there after 450+-
Old Nov 27, 2006 | 07:22 PM
What would be a good option for upgrading my pump and injectors. I am planning heads and spray in the next year.
Old Nov 27, 2006 | 07:42 PM
Jake@EPP's Avatar
A walboro 255 pump should be plenty for the stock bottom end with spray. Depending on what kind of shot you go with, if its dry i would get 42lb injectors if your going wet i would still get 38-42lbs.
