Esclade fueling help please!!!!!!!!!!
Old Nov 28, 2006 | 12:46 PM
1blackz28's Avatar
Default Esclade fueling help please!!!!!!!!!!
Ok so a few months ago we put a new fuel pump from autozone in a 99 esclade. The car ran fine for about a month or so then the pump went out agian. So the guy put another pump from autozone in it and the same thing happened ran fine for a month then bam it goes out agian. So my question is since it is verry unlikely that 2 new pumps go out. Does the esclade have a common problem that would cause it to burn up pumps. And I already told them that runing it out of fuel can burn up a pump and since the first one went out they havent let it run low. I realize this isnt an LSx based vehicle but Im suspecting an electrical issue and to be honest im not real great with eletrical problems. Ideas?
Old Nov 28, 2006 | 02:37 PM
Nasty N8's Avatar
It is not suprizing that 2 AutoZone pumps failed. Get a quiality pump for it and be done with it.
Old Nov 28, 2006 | 06:20 PM
nitroushane's Avatar
Have you checked the fuel filter?
Old Nov 28, 2006 | 08:13 PM
1blackz28's Avatar
Yes the second time the pump failed he changed the fuel filter. Anyother Ideas. TTT for the night crew.
Old Nov 29, 2006 | 11:13 AM
1blackz28's Avatar
TTT anyone elese have any ideas
Old Nov 29, 2006 | 10:08 PM
01350ss's Avatar
go buy a GM pump. Make sure the pump shuts off after the key is turned off also. I worked on a Yukon last year that the pump would continue to run for almost 11 minutes after the truck was turned off. The relay was slow to close.
Old Nov 30, 2006 | 11:16 AM
1blackz28's Avatar
Sounds good thanks
