ls7 42lb in ls1 ???
Old Dec 1, 2006 | 01:56 PM
99WS7's Avatar
Default ls7 42lb in ls1 ???
Will these work ok. Any tuning issues with these. Should I just stick to lucas/ford injectors for my ls1 or are the ls7 42lb injectors a good choice. Thanks for any help.
Old Dec 1, 2006 | 02:34 PM
OJmobileII's Avatar
different height and connectors. i picked up stock LS2 GTO/C6 34lb/hr injectors w/ rails for real, real cheap. found the injector plugs online somewhere and i'm going to try and make it all work on the cheap. but i dont think the LS7 injectors (probably wont get for that cheap) + other parts + time/headaches will be worth it.
Old Dec 1, 2006 | 02:55 PM
Dragaholic's Avatar
9 Second Club NA
Yes, LS7 injectors are shorter than LS1 injectors. That is easily fixable by lowering the fuel rails. Then all you would need is Katech's plug-n-play adapter harness. It allows you to install LS7 injectors into a LS1/LS6 vehicle. Its a simple swap.
