Save PSI for My Setup.
Old Dec 7, 2006 | 12:54 AM
JJ_TURBO's Avatar
11 Second Truck Club
Default Save PSI for My Setup.
Can someone tell me if its save to drop the fuel pressure lower than 50psi on the fpr so that my truck wont run rich? Since I change from the stock intake setup to the victor jr intake, nw 90mm throttle body and msd blaster coils, I can't even get on it half throttle cause the a/f ratio goes to 10's and the truck dosen't move, I have 75lb rc injectors which are the same that I had when I did the new setup, and it was running a little rich before but know its worst. I need to take the truck for a retune but that would be in a couple of weeks do I wanted to know if this will fix this problem or just the retune?
Heres the list of my truck setup,
STS 67mm turbo
3000 stall PI
Fuel Cell
Aeromotive A1000 Fuel pump
Aeromotive A1000 Regulator
Victor Jr Intake
Nick William 90mm Throttle Body
Intake Elbow
MSD Blaster Coils
Thanks,
JJ
Old Dec 7, 2006 | 09:58 AM
Nasty N8's Avatar
You can put the fuel pressure where ever you need as long as the rest is tuned accordingly.
Nate
