doing my fuel system, let me see some fuel rails
Old 12-07-2006, 04:12 PM
SELLSZ06's Avatar
Default doing my fuel system, let me see some fuel rails
Iam setting up my new fuel rails with a Edelbrock intake and I need top see what size hoses/fittings you guys are using and the way you are connecting them. Right now i have a two 90* elbow with 6an lines connecting to eachother on the front side of the rails. How do I route the back side of the rails, and connect it to my stock fuel lines. If you guys can post some pics. Do you think I need a fuel pressure regulator? I have 60lb injector and intank fuel pump.
Old 12-07-2006, 07:40 PM
Kuhnstyle86's Avatar
let me see if i can get some pics of mine
Aeromotive rails, aeromotive regulator pretty cool setup
Old 12-07-2006, 08:09 PM
Jake@EPP's Avatar
To run it back to your stock line you need to block off one of the backs(passenger), and then run a piece from the remaining rail into the special Russell fitting that clips onto the factory line.
To make it a return system, you would need to bypass the stock regulator and run a return line, typically this is used when the stock system is maxed out.
Old 12-07-2006, 10:18 PM
SELLSZ06's Avatar
thanks Ill find put if thats me after I go on the dyno
