Any one use this?
Old Dec 11, 2006 | 09:06 PM
SPRAYED 01's Avatar
Default Any one use this?
http://www.ls1speed.com/catagory.cfm.../%20Electrical
Looks to be an inexpensive voltage booster for a fuel pump. Its right next to the hot wire kit. Call the v-plus voltage booster. Thinking of using this with a racetronix plug and play for a budget 600wrhp fuel setup,
What do you guys think?
Old Dec 12, 2006 | 12:37 AM
BOONE's Avatar
Not to slight Speedinc but its only a couple volts, I just took mine off and threw it away because I didn't want to try to sell it. I'm going with a totaly new system. I think its sort of lame. If you want something like that just spend the money and go with the bap. Or a second intank, talk to Jake at EPP its cheaper than you think, cheaper than the bap, I believe.
Old Dec 20, 2006 | 08:20 PM
Smearin's Avatar
Cheaper for the second intank pump?
By Brett Foote | 2026-06-04 05:00:17
