injector size?
Old Dec 17, 2006 | 06:10 PM
caviness's Avatar
Default injector size?
what size injector for 450 to 550 rwhp? will my stock 2000 model injectors be big enough for 400 to 475?
Old Dec 17, 2006 | 08:04 PM
caviness's Avatar
maybe i posted in the wrong place?
Old Dec 17, 2006 | 08:15 PM
98LS1auto's Avatar
From what I've just been told 42's will handle that rwhp just fine and then some. I'm going to get 42's because I'm gonna spray and I'm not going to take any chances when it comes to making sure that my motor has enough fuel. Better safe than sorry. Fuel upgrades are cheaper than a new motor.
Old Dec 17, 2006 | 09:08 PM
caviness's Avatar
thanks for the info.
Old Dec 17, 2006 | 10:30 PM
Boodyrider's Avatar
42s are more than enough, even on juice or FI at those power levels... towards 475 rwhp you'd want to look closely at duty cycle if your getting there FI, but should still be fine.
Stock, despite some folks claims, are really beyond their ability to supply enough fuel SAFELY around 400.
Also... the 2000 injectors flow a bit less than the 98 or 01/02, so you'd be even further beyond the limits.
You could go 36, but the price of 42s is often lower than for 36s. And be aware that the Accel injectors have been known to fall short of advertised flow, sometimes dangerously so. Do a search for 42s you'll find some good deals out there.
Seriously consider pump upgrades as well, the Racetronics kit is well thought of.
Old Dec 18, 2006 | 12:09 AM
2 fast 2000's Avatar
The reason they flow less is because there smaller. 98,01,02's have bigger injectors (28lbs) from the factory. I have a 2000ss h/c, bolt-ons, and a 150 shot. At 560rwhp+ my injectors are fine, and they are factory 26lbs. Ran the car for over 100 passes and never had a problem. However I agree with you on the fuel pump upgrade though!
Old Dec 18, 2006 | 12:25 AM
caviness's Avatar
looks like 42 to be safe. then i want need to upgrade no time soon.
Old Dec 18, 2006 | 08:03 AM
john563's Avatar
Im cammed and heads are going in about a wk and wife just ordered a harris kit and im probly gonna do 100 shot.I was just wondering what rear do you have and are you an A4? dont know what these 10 bolts can hold on an a4
Old Dec 18, 2006 | 10:14 AM
caviness's Avatar
any more info. i need it.
Old Dec 18, 2006 | 10:38 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Yes, this sorta is the wrong place to post this, as it belongs in the fuel system section, but either way, here are my thoughts:
If you monitor your fuel pressure like I do, you'll quickly see that the stock fuel systems in these cars drop pressure with increased load. This requires the injectors to stay open longer to compensate for the pressure drop to keep the fueling where it needs to be, driving your injector duty cycle up. So really, there are a couple options here:
1. You get larger injectors that can compensate for any fuel pressure deviations without getting over 80% duty cycle
2. You upgrade the fuel pump
3. You find a way to regulate the fuel pressure so that it stays steady at the rails
In reality, it will probably take a combination of all three to get where you need to be with your fuel system. If you want to take the easier/cheaper way out, get some 42 lb/hr injectors and a Racetronix plug and play system. That should get you where you need to be. You wouldn't need as large of an injector if you could keep the rail pressure constant though, and I'm not sure how to fix that...yet.
Old Dec 18, 2006 | 05:01 PM
caviness's Avatar
thanks for the info guys.
Old Dec 18, 2006 | 06:51 PM
caviness's Avatar
thanks for moving my thread.
