Fast 36# injectors
Old Dec 27, 2006 | 05:17 PM
J's99Zrated's Avatar
Default Fast 36# injectors
I am building a 402 for my 99 Z28 w/ heads, a ms3 cam and bolt ons (also it might see a 100 shot later down the road). I talked to Jon at TSP and he recommended Fast 36# pound injectors for my set up when I asked him about the 42# that most people seem to run. He said that he uses smaller injectors on his 408 and spays a 200 shot. I trust Jon, but I am trying to figure out why most people run a huge injector then. Maybe I am completely off track but when I called Fast about the 36#, they said it was rated at 46psi. Is this why 36# would be good for my set up, because at 58 psi they should act like an injector closer 46#.
Old Jan 29, 2007 | 01:17 PM
silver98formula's Avatar
I was told the samething with my setup. We will see when the car goes to the dyno next week. Anyone else have imput on this matter?
Chris
Old Jan 29, 2007 | 01:35 PM
brad8266's Avatar
36 injectors are good for around 525 Flywheel HP (450 wheel HP) @ .5 BSFC, %80 Duty cycle, and 58 rail PSI.
Id go with 42lb injectors.
Old Jan 29, 2007 | 02:56 PM
Old Geezer's Avatar
Exclamation Yep..
I'd agree with the above...
I know of no inj mfgrs that use 46psi to rate their products.. [At least have seen none in the 10 yrs I've been doing injector flow testing/cleaning.]
If they are rated at 46psi, then running that inj at 58PSI, will not produce a flow of 46PPH.. It will produce a flow of 40.42PPH...
Back to
Old Jan 30, 2007 | 12:41 PM
Thanks for chiming in guys. I will post up when the car get done.
Chris
