What injectors for 355 LT1?
Old Jan 3, 2007 | 03:24 PM
Lt1Porsche's Avatar
Default What injectors for 355 LT1?
For my LT1 355 I know I need a flow rate of about 42 lbs/hr. But I am a bit confused between the low duty cycle (Low Impedence) and the high duty cycle injectors (High Impedence). Which do I need? Its a head and cam full bolt on motor. Output is about 550 bhp.
Old Feb 14, 2007 | 09:28 AM
Lt1Porsche's Avatar
b u m p
Old Feb 14, 2007 | 11:12 AM
camarols1's Avatar
If you are running a factory PCM you will need to use
the high impedence injectors.
