Heads+Cam=new fuel pump?
Old Jan 14, 2007 | 05:04 PM
fastest94v6's Avatar
Default Heads+Cam=new fuel pump?
I'm going the h/c route and just wanted to know if I'd have to upgrade my fuel pump as well? thanks!
Old Jan 14, 2007 | 05:14 PM
black01_WS6's Avatar
depends on how much power you are putting out. I would definatly change injectors out. Look into the racetronics set up for the fuel pump.
Old Jan 14, 2007 | 06:06 PM
import slayer's Avatar
how big of injectors should you use?
Old Jan 14, 2007 | 06:25 PM
stop hijacking my thread dude!
Old Jan 14, 2007 | 09:02 PM
Jake@EPP's Avatar
Typically a heads and cam setup will make low 400s. Depending on how many miles are on the injectors, they might be a little dirty. If you plan on doing a engine build or possibly a dry shot in the near future i would get a little bit larger injector. A fuel pump is allways a good idea when you get into the 400s. Go with a Fullthrottle speed pump and a casper hotwire kit.
Old Jan 14, 2007 | 11:30 PM
Yea, I was gonna upgrade the injectors and the fuel pump when i did the nitrous. Is it an absolute necesitty? I don't care if the fuel pump fails, as long as nothing else is at risk.
Old Jan 14, 2007 | 11:44 PM
Long Beach's Avatar
That would be a bad idea if it were to fail while you are wot because everything would be at risk. Maybe im wrong but if your fuel pump were to stop while you were wot, that would cause block damage.
Old Jan 15, 2007 | 01:30 AM
01sscam's Avatar
Man-Crush Warning
heads/cam 485rwhp here, stock fuel pump, i'll be getting a new one when i do nitrous.
