Fuel System Setup
Old Jan 18, 2007 | 04:12 PM
the_merv's Avatar
Veteran: Air Force
Default Fuel System Setup
What's up- trying to figure this out. I have a 95 Z28, LT1 with factory Fuel System(send/return lines on Rails). I am looking into putting a built LS2 into it. We are trying to figure out how to setup the Fuel System. Is there a way to adapt the early F-body LS1 Fuel Rails with the send/return lines on them to the stock LT1 System, or will I have to pretty much get everything LS1, and run with that. I have a Fuel Pump Acess Panel already made, so messing in that area is no problem..
Old Jan 18, 2007 | 05:07 PM
Nasty N8's Avatar
Yes give me a call I can help you figure it out.
Nate
Old Jan 18, 2007 | 05:26 PM
the_merv's Avatar
Veteran: Air Force
Got it, thanks to this guy above me.
http://www.oreillyauto.com/EW3/Produ...riptionId=1475
