Injector question?????????????
Old Jan 19, 2007 | 08:40 PM
98ws6firebird's Avatar
Default Injector question?????????????
After you do a h/c swap and hopefully pick up that big horsepower will your pcm
be able to add enough extra fuel to compensate. I'm going ms4 and prc heads
this combo has been making 107 rwhp. If my stock injectors are at 98% duty
cycle already will I have enough injector and can it and that much more fuel by
itself . I can install my 42lbs injectors but
that would be to rich. Can the computer lean it back far enough? I will get this
car tuned as soon as I can but I know I'm gonna want to drive as soon as the
swap is done. I don't want to go lean and wreck something before I get it tuned.
Old Jan 19, 2007 | 11:54 PM
ZL1Killa's Avatar
ok. plain and simple. don't get on it, do the install, leave the stock injectors, DON"T GET ON IT. there is no way in hell that you are going to go beyond your duty cycle at idle and what not. IF YOU CHANGE INJECTORS YOU MUST TUNE FOR IT. YOU MUST TUNE FOR IT.
if you don't want to go lean and wreck/break something then DON"T GET ON IT after the install. wait and get it tuned with the new injectors
