what do i need to make my Walbro work?
Old Jan 25, 2007 | 10:14 AM
cyamaha2007's Avatar
Default what do i need to make my Walbro work?
i have tried the search and cant find what i need. All i have is the pump its self i dont have the wireing harness or anything is there a way to make it work with spade conectors? if there is a good write up on how to do the entire thing id apreciate it.
Thanks
Old Jan 25, 2007 | 12:12 PM
stealth71's Avatar
Look here they can get the wiring to you: http://www.lonniesperformance.com/
I personally wouldn't use home made stuff sitting in my gas tank, unless you use the correct type of wire and connectors.
Old Jan 26, 2007 | 10:47 AM
Full Throttle's Avatar
If you have a pump we have the connector with the termainals on it so it can be inserted into your hangar assembly, If you want to call me I will be happy to see if we can help you out.
Mike
586 294 4404
