stock fuel pump and injector limits
Old Feb 8, 2007 | 02:23 PM
408 z28's Avatar
Default stock fuel pump and injector limits
im just curious as to what all you can get away with on a stock fuel system with stock injectors as far as heads, cams, n20 goes...
thanks
eric
Old Feb 8, 2007 | 08:50 PM
RedHardSupra's Avatar
<360rwhp safely. fuel injectors are dinky, and even if you upgrade these, the fuel pump doesn't catch up at higher rpm so you gotta upgrade that too. stock stuff is really for bolton-only applications
Old Feb 9, 2007 | 12:08 AM
Alex L.'s Avatar
Been pushing 430-450rwh with 98 28lbs injectors for 5 years.... 7200rpm.. Your 2000 is probably good for around that range too, maybe a bit lower. Stock fuel pump too. Stroker motors need bigger injectors though even if they are making similar horsepower.
Old Feb 9, 2007 | 12:50 AM
SSilverSSurfer's Avatar
ive been at 400hp for a while, havent had any problems, but then again i have a set of 60lb injectors and im getting ready to get the Nasty Performance Stage 2 set up pretty soon,
