IS an inline pump enough for turbo?????!!!
Old Feb 18, 2007 | 10:52 PM
Eatinstang4life's Avatar
Default IS an inline pump enough for turbo?????!!!
Well I am going with a turbo set up on my 01 ws6 plan in runnig about 7-8 psi and hoping for about 450rwhp, Will a good inline pump work ro supply enough fuel for this set-up? I know I will need some injectors.
Old Feb 18, 2007 | 11:06 PM
brad8266's Avatar
maybe, id get a intank though.
Old Feb 19, 2007 | 02:23 AM
redrocketSS's Avatar
Look at getting an MSD boost-a-pump, it basically sends more power to the fuel pump at higher levels of boost that way you dont have to worry about running to rich at low boost or to lean at high boost
Old Feb 19, 2007 | 02:58 AM
GEARHED's Avatar
There are some good sponsors you can call or email and see what they would suggest. It's how I figured out what in tank to use
Old Feb 19, 2007 | 08:00 AM
thanks
Old Feb 19, 2007 | 12:26 PM
Nasty N8's Avatar
A single Walbro intank is what you will need. adding an inline will not help it will not pull more fuel than your stock pump can muster.
Nate
