fuel damper needed?
Old Feb 20, 2007 | 07:38 PM
jtl12419's Avatar
Default fuel damper needed?
The LS1 fuel rail appears to have fuel damper. The LS2 rail does not. Is there a reason to use or not use a damper?
I am converting my F-body LS1 to a LS2 402 engine. What fuel system alterations will I need? I currently have a Walbro pump and Aeromotive FPR prior to the rail, running 42# injectors through Billet -8 AN rails.
Old Feb 20, 2007 | 10:57 PM
DrkPhx's Avatar
I don't know why GM chose bot use a damper on the LS2. I have a LS2 402 with the stock fuel rails and similar fuel system as you with no problems.
