What Is a "Return Style" fuel system?
Old Feb 21, 2007 | 02:59 PM
gdbauer7's Avatar
Default What Is a "Return Style" fuel system?
What actually is a Return Style fuel system? And how does it work?
Old Feb 21, 2007 | 10:01 PM
nahasapeemapetalon's Avatar
I believe its just reffering to the gas returning to the tank ...witha return line. SOme systems dont have a return line. Just circulates is how it works.
Old Feb 22, 2007 | 12:52 AM
b727pic's Avatar
Since not many replies I'll throw in my .02 on the description.
a non return style system regulates the fuel pressure in the fuel tank itself, with only regulated pressure going to the fuel rails....hence only 1 line going up front. The unused fuel is "recirculated" in the tank, in many cases this bypassed pressure is used to power a "venturi" that uses motive flow to aid in keeping our fuel buckets full of fuel.
conversely, a return style will have two fuel lines running to the engine compartment. Generally this setup will have the fuel regulator on the fuel rail. all fuel that is sensed by the regulator to be in excess of the engines demands at a given fuel pressure setting is then "bypassed" through the second fuel line back to the fuel tank.
that in a nut shell is the differences...
