cammed only w/42lbers
Old Feb 25, 2007 | 06:50 PM
1969x11's Avatar
Default cammed only w/42lbers
Can my cam,header,ls6 intake lq9 6.0l be tuned to run right on 42 lb green tops.BTW. its a small cam 226/226 .585/.585. Thanks guys
Old Feb 25, 2007 | 07:08 PM
zlover129's Avatar
yes it can be tuned to use them, but does it need them? No, it will come in handy down the road when you do start needing more fuel but you will not be able to use it without a good tune. But if im not mistaken a dyno tune will allow the tuner to adjust the pulse from the injectors and prevent it from running rich
Old Feb 25, 2007 | 08:29 PM
DuronClocker's Avatar
If you plan on heads in the future, or a dry shot, definitely buy the 42's. I went with 30's and it is holding me back from running a dry shot. Perfect injector size for what I have now, but a dry shot would be asking WAYY too much of them.
