fuel pump problem
Old Feb 27, 2007 | 02:14 PM
99SeanWS6's Avatar
Default fuel pump problem
my car was down for about a year and i got it running around a month ago. at first it was running fine. i replaced the fuel filter but it is running rough. it idles fine and everything but when i put it in drive it wants to die. sometime it will go into drive just fine and drive fine but when im driving it will be sluggish and not want to go and even sometimes it will just die on me while im driving. since i've had it back i've gone through about 1 hole tank of gas. someone mentioned the fuel pump. any ideas what it might be.
Old Feb 27, 2007 | 02:23 PM
04 Impulse's Avatar
Was the gas old and tarnished? did you try to run again since the tank was emptied on fresh gas? could be the pump, but could have just been old gas.
Old Feb 27, 2007 | 02:48 PM
99SeanWS6's Avatar
when i started it up this year it had half a tank of gas. i ran that down to a 1/4 then filled it up and added some cleaner stuff. this is that tank mixed with the old/new/cleaner
Old Feb 27, 2007 | 03:08 PM
04 Impulse's Avatar
hmmm maybe the sock is all sludged up, or the filter, looks like you may be going into the tank either way.
Old Feb 28, 2007 | 07:16 AM
99SeanWS6's Avatar
any other ideas?
Old Feb 28, 2007 | 05:08 PM
04 Impulse's Avatar
Pop out the injectors, make sure they arent blocked up?
Old Mar 21, 2007 | 08:39 PM
ss2668's Avatar
You ever figure out what was wrong?
