Wheres the fuel pump relay?
Old Feb 28, 2007 | 10:49 PM
nvmy2000ss's Avatar
Default Wheres the fuel pump relay?
I am installing a MSD boost a pump and it says to run the relay of off it to the factor relay. Anyone know where this is and where it goes.
Old Mar 1, 2007 | 03:58 AM
FlightMechYJ's Avatar
It under the hood in Fuse block assembly 2 Which should be on the forward drivers side of the engine compartment.
Old Mar 1, 2007 | 11:14 AM
Nasty N8's Avatar
It is under the rear driver side seat but you can access the wire you need out back by the plug exiting the car it is a Gray wire going to feed the fuel pump.
Nate
Old Mar 1, 2007 | 03:17 PM
98turbls1's Avatar
I this going to be the same for 98???
Old Mar 1, 2007 | 04:24 PM
nvmy2000ss's Avatar
I also have a hot wire kit that I forgot to mention and was wondering when I tap into the hot wire kit with the supplied connectors should the wire from the bap go into the connection that goes tword the pump or tword the relay.
I would think to the pump but I thought I would make sure.
Old Mar 5, 2007 | 08:17 PM
Got Me SOM's Avatar
if you have the hot wire kit, you just plug the bap inline to the pump and ground the two wires on the chassis. the orange wire and 30 amp fuse should be connected together.
