what fuel pressure?
Old Mar 9, 2007 | 03:28 PM
1320 killer's Avatar
Default what fuel pressure?
Well, just like the title says. I have tried to search this and I can't seem to find the answer. I have a 99 camaro ls1 with all the bolt ons and 42 pound injectors. I have my fuel pressure set at 57 psi. what does everyone else have their pressure set at?
Old Mar 9, 2007 | 07:33 PM
code4's Avatar
factory psi is 58, this is where i have mine set at
Old Mar 12, 2007 | 07:46 AM
z28drag's Avatar
stock pressure 57-58 psi same thing, this pressure is need to run the ls1 engine...
Old Mar 12, 2007 | 10:00 AM
I am not sure how true it is but I was told that if you run svo injectors, your ls1 pressure needs to down 3 to4 psi. does anyone know if this is true
Old Mar 13, 2007 | 03:29 PM
code4's Avatar
I have never heard that, you can vary your fuel pressure if you want as long as your tuned for that pressure.
Old Mar 13, 2007 | 07:21 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
SVO injectors are generally rated at 39PSI.
The industry standard is generally 43.5PSI.
This would equate to an apx. 5.6% increase in fuel flow over the SVO pressure rating.
The LS1 cars run at 58PSI nominal which is an apx. 21.9% flow increase over the SVO pressure rating.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 13, 2007 | 10:01 PM
MNR-0's Avatar
Why not run as max. fuel pressure as you can get? Of course, you would need to rescale your injectors. More fuel is good...
Old Mar 14, 2007 | 12:50 AM
Racetronix's Avatar
LS1TECH Sponsor
It would be best to keep the base fuel pressure at 58PSI.
__________________
>WEB SITE<
