Car running extremely lean...
Allright, heres what happened. i just got nitrous for my car a while back. I just went to the dyno to see what the car would do. I mainly wanted to get a feel for the AFR because i dont have a guage right now. Long story short, we strapped it down, and ran a baseline NA, and the car was at 18:1 the WHOLE RPM band. we thought it was his sensors, so he put on some new ones, and it was the same thing. tried them out on a pickup, and they read fine. so my car is definitely reading that lean, and i dont know why. i have TSP's 233/239 cam, headers, ORY. I also have a mail order tune from them. The last time i dynoed my car it ran around 370hp without a dyno tune, which wasnt that bad. but now im running lean and cranking out a whopping 277hp. What could be the problem here? we checked the fuel pressure and it was around 58-62 psi. but the car is still extremely lean. any suggestions? has this happened to anyone else?
There isn't much info here though...
dry or wet nitrous?
stock fuel pump?
did you do anything like swap MAFs?
what changes since last dynoof 370 besides the tune?
anyway to check the tune and determine if the IFR got accidentally raised and wasn't supposed to?
FWIW a mail order tune should be used to get your car to a tuner.
Fix that problem. If the PCM doesn't know where the engine load is, there'll be no fuel control.
doh! I missed that....
Yep.
