Injector Help
Old Mar 13, 2007 | 12:56 PM
10secsts's Avatar
Default Injector Help
Hoping someone could tell me where I can get my injectors flow tested. Thought I remembered one of the sponsors doing it, but don't remember which one. Tried to search, but it's not working.
Old Mar 13, 2007 | 07:02 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
This company is not affiliated with Racetronix however we do recommend their services:
http://www.witchhunter.com/index.php4
They are one of the few companies out there that actually know what they are doing.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 13, 2007 | 08:36 PM
10secsts's Avatar
Thanks for the info.
Old Mar 14, 2007 | 03:32 AM
koolaid_kid's Avatar
Wow, that is pricey. There is a vendor that charges 10 per injector. Do a search when it works. If I find it, I will post for you.
Old Mar 14, 2007 | 08:55 AM
Racetronix's Avatar
LS1TECH Sponsor
Some vendors who own an injector flow bench do not know how to properly use them. A thorough inspection is time consuming so make sure you compare services. An oscilloscope is required among other devices to properly check injectors. The equipment used is only as good as the person using it.
__________________
>WEB SITE<
Old Mar 14, 2007 | 11:27 AM
Here is the link: http://www.affordable-fuel-injection...r-cleaning.htm
Old Mar 14, 2007 | 11:53 AM
02 z/28's Avatar
new era
Old Mar 14, 2007 | 08:56 PM
405HP_Z06's Avatar
Here's another that does good work:
http://www.cruzinperformance.com/
Old Mar 15, 2007 | 08:28 PM
Mike @ New Era's Avatar
We can take care of it for you , you can order the service right here www.neweraperformanceparts.com and then send in your injectors with the created invoice .
Mike
